carole
Std Dev Lower and Upper 95% from oneway analysis details of calculation
I am in JMP17.2.0 Pro
could you please explain me how is computed Std Dev Lower and Upper 95% in the example below ?
Especially why the interval is not symmetric around the StdDev value ?
Thank you very much.
platoneway = Oneway(
	Y( :weight ),
	X( :age ),
	Each Pair( 1 ),
	All Pairs( 1 ),
	Comparison Circles( 0 ),
	Means and Std Dev( 1 ),
	Box Plots( 1 ),
	Mean Diamonds( 1 ),
	Mean Error Bars( 1 ),
	Std Dev Lines( 1 ),
	Grand Mean( 0 ),
		Dispatch(
			{"Means and Std Deviations"},
			"Std Dev Lower 95%",
			NumberColBox,
			{Visibility( "Visible" )}
		Dispatch(
			"Std Dev Upper 95%",
			NumberColBox,
		Dispatch(
			"~Std Dev",
			PlotColBox,
		Dispatch( {}, "Means Comparisons", OutlineBox, {Close( 1 )} )
MRB3855
Re: Std Dev Lower and Upper 95% from oneway analysis details of calculation
Hi @carole : Yes, it is not symmetric.  It is calculated as shown in the link below.
https://www.statology.org/confidence-interval-standard-deviation/
Why not symmetric? The answer has to with the distribution of the sample SD; it is based on a skewed distribution (the Chi-Squared distribution).
MRB3855
carole
Thanks a lot for the link very interesting, and your answer.
Best regards,
Carole
