rshehadah
Stat test for proportions
I have a dataset with 8 different categories. For each category I ran a test and recorded true or false. I want to know a statistical test I can use to see which groups are different from each other.
Thank you,
Rami
Thierry_S
Re: Stat test for proportions
Assuming that you have several results (TRUE / FALSE) for each category, you could simply use the "Fit Y by X" function under the Analysis menu.
Make sure that both the X (8 categories) and Y (the test results) are set to nominal.
Now if you have only one level (True or False) for each category, I don't think you can do much with that data.
Thierry R. Sornasse
Article Labels
