BookmarkSubscribeRSS Feed
mcstagger
Oct 6, 2014
Stat Testing and Data Tables
Hello All!
New JMP user here with a Tabulate question. I am trying to achieve a data table look that I have been familiar with up to this point which looks similar to the below:
Group 1Group 2
Base Size300300
AB
Age
18-24
10%25%A
25-3420%20%
35-4430%30%
45-5420%15%
55+20%B10%
So far I am having luck developing the general look of a table like the above excluding the stat testing.
My question is, can I create a table like the above in JMP? If so, can someone point me towards a resource that goes through the steps?
julian
Jun 25, 2014
Solution
Re: Stat Testing and Data Tables
Hi mcstagger,
My apologies for not interpreting correctly, you want that table exactly! Tabulate is powerful, but you won't be able to move around the sections to make exactly that table. Tabulate is also not built for doing analyses, only tabulating. If you wish to reveal the contingency test, you will need to use Analyze > Fit Y by X, or Analyze > Consumer Research > Categorical. Each of those platforms will make a table close to what you want, but not exactly I'm sorry to say. In case it helps, here is the set up for both of those platforms.
I'm sorry I don't have steps to make that exact table, but I hope this gets you a little bit closer.
Julian
11 REPLIES 11
julian
Jun 25, 2014
Hi mcstagger,
Using tabulate you can make a table very much like the one you have posted. The exact steps depend on how your original data table is structured. Would you be willing to post your data, or some sample data with the same format? If so, I would be happy to write out some steps.
Julian
mcstagger
Oct 6, 2014
Julian,
Could we use a sample data set provided with JMP?
Using the attached with "Gender" as our banner and "Goals" as our stub should work.
Thank you for the assistance Julian.
julian
Jun 25, 2014
Hi mcstagger
Of course. Here's a quick video of the steps I would go through to make that sort of table. Does this get you to where you want?
I hope this helps!
Julian
mcstagger
Oct 6, 2014
Julian,
What you have shown me is pretty much where I have been able to get. The pieces that I am looking for now are:
  1. Getting the column base size to show up above the column it represents, i.e. Male (n=227) and Female (n=251)
  2. Stat testing between column A (males) and B (females)
stan_koprowski
Community Manager
Aug 8, 2012
Alternatively, if you are using JMP 11 you could use the Categorical platform under the Consumer Research menu.
Using the Children's Popularity data table and using the breakout and stub you suggested will produce the following:
Best,
Stan
mcstagger
Oct 6, 2014
Stan,
Thank you for helping out as well. Please see my latest response to Julian. What I am looking for is more consistent formatting to what I had initially posted, along with the steps, if possible, to show column stat testing.
julian
Jun 25, 2014
Solution
Hi mcstagger,
Julian
mcstagger
Oct 6, 2014
That is what I was afraid of. Thanks much Julian!
julian
Jun 25, 2014
One more try -- hacking things together here a bit    Hope this gives you some ideas.
Julian
