axcelenator1
Standardize attributes of columns is not working
Hello, I have the following code: I want the new columns generated inside the dt will be as a numeric&continuous so I can force on the data some variabilty charts and other things. But after running the script the data is still remains as Character & Nominal
dt = New Table( "myExample2", Add Rows( 3 ), New Column( "Column 1", Numeric, Continuous, Format( "Best", 8 ), Set Selected, Set Values( [2, 5, 8] ) ), New Column( "Column 2", Character, Nominal, Set Values( {"5|6|5", "5|6|5", "5|6|5"} ) ), Set Row States( [0, 0, 1] ) ); For( i = 1, i<= 3, i++, dt << New Column ("C" || char(i), Numeric, Continuous, Formula( Word( i, As Column( Column( "Column 2" ) ), "|" ) ) ) );
Re: Standardize attributes of columns is not working
First, you can use the name directly, :Column 2, without the As Column() directive.
Second, put the Word() function inside the Num() function to convert the value to a number.
