Stacking overlay plots
I thought I might be able to stack overlay plots into one window in a script like this:
Distribution(
stack( 1 ),
Overlay Plot(
X( :static_clear_rel ),
Y( :MxBmin, :Pred Formula MxBmin ),
Sort X( 0 )
Overlay Plot(
Y( :MxBmax, :Pred Formula MxBmax ),
Sort X( 0 )
But no window pops up, and I get no warnings/errors. If I change it to the following, I do get 2 separate windows to popup:
//Distribution(
// stack( 1 ),
Overlay Plot(
Sort X( 0 )
Overlay Plot(
Sort X( 0 )
afterword
Re: Stacking overlay plots
You may need to enclose the Overlay scripts in a
New Window("Window Name", XXXX)
Replace the XXXX with the scripts you're trying to paste together. You can format the output using horizontal and vertical list boxes (vlistbox and hlistbox).
chungwei
Another way would be to stack your data, then just use one overlay with grouping column.
You can use the frame box copy and paste feature to stick the charts together.
new window("my wnd",
c1= Overlay Plot(
Sort X( 0 )
c2 = Overlay Plot(
Sort X( 0 )
// copy the framebox of the first chart and drop it on the second.
fb1 = (c1<< report())[framebox(1)];
fb1 << copy frame contents();
fb2 = (c2<< report())[framebox(1)];
fb2 << paste frame contents();
// you can now delete the first chart if you want.
c1 << delete();
