padhikari
Stacking columns
I have columns call max humidity, 30s after, 1 minute after max, 2 minute after max....and I have columns that says max hume from dome close, 30s after max humid to dome close.
I was wondering if there is way to stack the column that would show me the max humidity value to max humid from dome close.
As you go right on the right, the values of humidity are decreasing and time are increasing. I want to create Yvs X from those columns, and x and y values would be continuous.
Thanks,
Pratish
Re: Stacking columns
Tables==>Stack
will let you stack multiple groups of stacking columns.  It is called Multiple serices stacking.  You can stack all of your Max Humidity columns in one series, and all of your Max Humidity from Dome Close in a second column, and then you will have what you want.  Take a look at the Stack platform.  You can look in the Using JMP for documentation on how this works.
     Help==>Books==>>Using JMP
Tables==>Stack
