msharp
Stacking Just One Column
I was disappointed to find out that JMP resricts us from stacking just one column.  I understand that stacking just one column doesn't make sense, however, since it's just a data transform it does make sense to want to do it.
Anyways, I wanted to open up the conversation and see who can come up with a better work around than I did.  Here's mine:
Names Default to Here(1);
//Example Data Table
dt = Open( "$SAMPLE_DATA/Decathlon.jmp" );
//col list is list of columns from 1 to n (never an empty list)
colList = {"Javelin", "Pole Vault"};
//Stack columns to prepare data for analysis
if(nitems(colList) > 1,
	analysisColsExpr = Expr(columns());
	for(i=1; imax=nitems(colList), i<=imax, i++,
		col = Column(dt, colList[i]);
		insert into(analysisColsExpr, col);
	dtAnalysis = Eval(Eval Expr(dt << Stack(
		Expr( Name Expr( analysisColsExpr )),
		Source Label Column( "AnalysisType" ),
		Stacked Data Column( "AnalysisValue" ),
		Output Table( "Stacked Data" )
	close(dt, nosave);
	//Can't stack only one column adjust columns to match above strategy
	dt << New Column("AnalysisType", Character, Nominal, Formula(colList[1]));
	column(dt, colList[1]) << Set Name("AnalysisValue");
	dt << Set Name("Stacked Data");
	dtAnalysis = dt;
//Run Analysis
oneway = dtAnalysis << Oneway( Y( :AnalysisValue ), X( :AnalysisType ) );
Good Luck!
ms
Super User ms
Re: Stacking Just One Column
Here's an alternative that does not mess up the original table if there is only one column, i.e. creates a new table (like Stack() does) instead of adapting the original table to the approach.
dt = Open("$SAMPLE_DATA/Decathlon.jmp");
If(N Items(colList) > 1,
    dtAnalysis = dt << Stack(
        Columns(colList),
        Source Label Column("AnalysisType"),
        Stacked Data Column("AnalysisValue"),
        Output Table("Stacked Data")
    dtAnalysis = New Table("Stacked Data",
        addrows(N Rows(dt)),
        New Column("AnalysisType", character, set each value(colList[1])),
        New Column("AnalysisValue", numeric, values(Column(dt, colList[1]) << getvalues))
//Run Analysis
oneway = dtAnalysis << Oneway(Y(:AnalysisValue), X(:AnalysisType));
ms
Super User ms
Another approach without a conditional (assuming original data table has >1 rows):
dtTemp = dt << Transpose(Private, Columns(colList), Label Column Name("AnalysisType"));
stackList = (dtTemp << get column names)[2 :: N Row(dt) + 1];
dtAnalysis = dtTemp << Stack(
    Columns(stackList),
//Run Analysis
msharp
This is a great strategy and works perfectly in JMP 13, however, in JMP 12 since Name is a Label column it automatically throws it in as a label column for the Transpose function--short circuiting the strategy.  Not sure if that was a bug, but glad it is fixed in JMP 13.  Unfortunately, I'm the only one on my team that has JMP 13 currently...
Article Labels
