axcelenator1
Stack a group of columns
Hello, I have some table with a group of columns. I want to stack the group with a script how can I do that?
dt = open("C:\Users\My.jmp");
s_list = {h1, j2, k3};//List
//Generate XX new columns by Text to Cols ADD-In
For( i = 1, i<= Length(s_list), i++,
	    dt << New Column  ("My_New_Coloumn_" || s_list[i],
		Numeric,
		Continuous,
		Formula(
				Num(Word( i, As Column(Column("CPU" )), "|" ))//CPU is a column that contains for example: 5|5|7
dt << Group Columns(:My_New_Column_h1,3);
Here I try to stack the aboved Group
jerry_cooper
Staff (Retired)
Re: Stack a group of columns
Hi @axcelenator1,
Does the example below help for what you are trying to do?
dt = Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
group = dt << Group Columns( BP 8M, 9 );
dt << Stack(
	columns(
		dt << Get Column Group( group );
	Source Label Column( "Label" ),
	Stacked Data Column( "Data" )
Interactively run the Stack Platform on your 3 columns
     Tables==>Stack
and then in the new table created, Edit the source for the table, and you will see the JSL necessary to stack the columns the way you want.
axcelenator1
actually my s_list is a randomal list bigger than 3 items that is changing all the time.
The stack JSL gives the new columns names that were generated and concatenated inside the For Loop. I need to find a solution to something like generating a List and put it inside the Columns in the Stack function but I can't get it....
Apparently I am confused on what you actually want to accomplish. In JMP Stacking typically implies that one is stacking two or more columns on top of each other. Grouping of Columns makes organizational groups of columns, that allow for the easy handling of them for use with the various platforms.
Could you provide more detail on what you want your data table, and any new columns you are creating to look like?
axcelenator1
I have something like 19 columns that are stacked together. The names of the columns are generated in the aboved loop that is posted.
I want to make an auto script that will use the column names generated above and use it inside the Stack() function.
Stack(Columns("***Here I want the auto script to generate the columns names***")...........
jerry_cooper
Staff (Retired)
Hi @axcelenator1,
dt << Stack(
	columns(
