viskovicz00012
Split if Cell Value Contains
dt3 = dt2 << Split(
        Split By( :ONP ),
        Split( :GLE, :OTS ),
        Output Table( "Split_data" ),
        Sort by Column Property);
This is a part of the automation script i made which is ran on daily schedule  -- somehow some datasets ran with this script doesnt contain both columns i.e GLE and OTS, How do i split dt2 such that it checks first if the dataset if it contains either(GLE only/OTS only) or both of them(GLE & OTS) and somehow splits the table?
Re: Split if Cell Value Contains
Here is the most straight forward version.....not the prettiest.
If(
	Try( dt2:GLE << get name, "" ) != "" &
	Try( dt2:OTS << get name, "" ) != "",
		dt3 = dt2 << Split(
			Split By( :ONP ),
	Try( dt2:GLE << get name, "" ) != "",
		dt3 = dt2 << Split(
			Split By( :ONP ),
			Split( :GLE ),
		dt3 = dt2 << Split(
			Split By( :ONP ),
			Split( :OTS ),
