matthewh
Community Trekker
Spec limits on oneway chart
Probably a very simple question...
I have a data column of continuous numeric data with upper and lower spec limits defined in the column properties.
When I create a oneway chart (in my case, a box plot), is there a way to automatically rescale the axis and add the spec lines on the graph in JSL (in the same way that the distribution platform does)?
If not, can I get access to the spec values so that I can manually change the axis scale and put reference lines on?
Thanks,
Matthew.
mpb
Super User mpb
Re: Spec limits on oneway chart
A forum search for "plot spec limits" turns up, among others, this thread which may help:
http://support.sas.com/forums/thread.jspa?messageID=27171樣
