powerpuff
Spec limits and response limits
Is there any way I can add spec limits and response limits to all columns in a table simultaneously?
7 REPLIES 7
Re: Spec limits and response limits
You can use the Standardize Attributes dialog under the Cols pull down menu.  Just select all of the columns you want to set, and then open the Standardize Attributies, and enter the desired Spec and Response Limits
Or, if you have different Spec Limits, you can use the add in from the JMP File Exchange
Write Limits to a Data Table from a Limits Table
powerpuff
@txnelson but what if I have different limits for each column? The "Standardize attributes" gives me the option to give the same value to all thecolumns. Thanks
powerpuff
This addin really helps, but only for spec limits. Is there anything similar for response limits as well? I have many columns and different goals and importances for all.
I need to update the Addin to handle Response Limits......but that will not be today.......
I am not aware of any other Addin that handles Response Limits.
powerpuff
@txnelson thanks for the update.
powerpuff
Is there any way I can add response limits to all columns using jsl though?
Of course there is.  If you look at the script from the Addin, you can see how the other limits are added, and from there you can modify the method to add the reponse limits.
