Dennisbur
Sort by
Hello
I have a table with 2 columns, "% of Total" and "Correlation"
I would like to sort simultaneously both columns in Descending only
but when I run the script, the column Correlation is sorted like Descending but % of Total is sorted like Ascending
What is wrong with my script?
dt << sort ( by ( "Correlation" , "% of Total" ), Order ( Descending ), Replace table );
Re: Sort by
As you want to sort both in same direction, perform the action interactively and get the script from enhanced log
// Open Data Table: Big Class.jmp
// → Data Table("Big Class")
Open("$SAMPLE_DATA/Big Class.jmp");
// Sort data table
Data Table("Big Class") << Sort(
	By(:height, :weight),
	Replace Table,
	Order(Descending, Descending)
Most likely it is using default sorting for the second column which seems to be ascending
Re: Sort by
// Sort data table
	Replace Table,
