nihal96
Sort and Group Data Set
I have a list of variables. I want to group certain variables under certain groups.
For example, I have a list of variables: a, a, b, b, b, b, c, d, d, e, e, e
I want to sort the variables:
  • a, b and c as "control".
  • d and as "low spec"
I thought I could use the if and or functions from the formula editor as shown below but it doesn't seem to work
If( :Column 74 == ("a" | "b"),
	"control",
	"low spec"
Re: Sort and Group Data Set
The correct syntax for what you are attempting to do is:
If( :Column 74 ==  "a" | :Column 74 == "b",
	"control",
	"low spec"
If( contains({"a","b"},:Column 74)
	"control",
	"low spec"
Or you could use the Contains() function
