[Solved] Copying associative arrays
This code works in JMP 7 but not JMP 9
x["one"] = {1,2,3,4,5};
x["two"]={"one","two","three"};
y=x;
y["three"]={4,5,6};
in JMP 9 y will act as if it is read only and y["three"] will not exist. Why is this the case and how do I fix it?
Message was edited by: Justin
Re: Copying associative arrays
Solved my own problem. In my case y was really called project and it must be some kind of reserved work in JMP 9. Calling it anything else makes it work
