lwx228
So how do this quickly in excel using JSL?
As shown in figure:
Open Probe file:Copy the "Start Time" column and J column of the "DELL_RPNBR" file to excel
Enter formula I in excel[C5]:=IF(B5=MAX(B2:B8),A5,0)
How is this implemented in JMP with JSL?Can I only use the FOR loop?Thank you very much!
Re: So how do this quickly in excel using JSL?
I believe a formula below, or something close to this will work:
If(
	:DELL_RPNBR == Max(
		Max( :DELL_RPNBR[Index( Row() - 4, Row() - 1 )] ),
		Max( :DELL_RPNBR[Index( Row() + 1, Row() + 4 )] )
	:Start Time,
	0
7 REPLIES 7
lwx228
Input formula in column "Site" and calculate according to the following requirements:
If the value of a row in "DELL_RPNBR" column is the maximum of 3 rows above it and 3 rows below it, the value of the same row in "Start Time" column is returned; otherwise, "Site" row[] it is 0.
lwx228
dt = Open( "$SAMPLE_DATA/Probe.jmp" );
If(
	:DELL_RPNBR == Max(
	:Start Time,
	0
lwx228
Thank Jim!
If(
:DELL_RPNBR == Max(
Max( :DELL_RPNBR[Index( Row() - 4, Row())] ),
Max( :DELL_RPNBR[Index( Row() , Row() + 4 )] )
:Start Time,
0
lwx228
This method is very practical !
lwx228
lwx228
it should be
If(:DELL_RPNBR==(Max(:DELL_RPNBR[Index(Row()-4,Row()+4)])),:Start Time,0)
