BookmarkSubscribeRSS Feed
Smooth Curve Scripting
I am trying to automate a capability analysis using the Smooth Curve fit within the Distribution command. I have it built so that a user can enter in a quantile to generate the USL, but I can't figure out how to have the script automatically generate the capability analysis based on the quantile the user entered. If I click on the option to generate the capability and then send the script to the script window the code contains the spec limit option, not the capability option. Any ideas?
