BookmarkSubscribeRSS Feed
hupin
Aug 11, 2013
Simulate ooc% for different spec limit
Dear Expert,
I have set of data, want to simulate the ooc% for different spec limit setting:
usually I use the distribution--> capability analysis --> set spec limit--> get the ooc%,
but this is quite manual, each time only get one set of ooc% for the corresponding spec limit setting
I'd like to see more, like kind of simulation, very dynamic, just drag the spec limit to different value, then can immediate see the ooc% appear onto the graph
Is it possible ? thank you
