AngeloF88
Simple line and starter plot
I have the export in the table the results of Mixed model. I detail, I have export the Predicted and stardard deviation. Now I would like to make a graph with the predicted rapresented by line and the standard deviation values rapresented by bars. In the x - axes the data is categorical.
How, I can produce a Simple line and scatter plot with graph build in JMP ?
or
How, I can exported the the the standard deviation directly from profile ?
This beacause, I have to try to produce a table and and a random table, but the standard deviation visible in the "profile graphic" there was not showed in the graphics build from table and random table.
Thank you so much,
Angelo
