volf
Staff (Retired)
Simple SQL change to JSL code
Hi JMPers,
How to change Simple SQL to JSL code.
Thanks,
mattf
Level V
Re: Simple SQL change to JSL code
Hi:
Here is one way to create such a table - There are undoubtably others.
Best regards,
-Matt
df = dt << Data Filter(
Mode( Show( 0 ) ),
Add Filter(
columns( :age ),
Where( :weight >= 30 & :weight <= 100 )
Data Table( "Big Class" ) << Subset(
Copy formula( 0 ),
Rows( [1, 3, 5, 6, 8, 11, 12, 14, 15, 16, 17, 19, 20, 21, 22, 24, 26, 28] ),
columns( :age )
mattf
Level V
Hi:
Best regards,
-Matt
mattf
Level V
Hi:
Best regards,
-Matt
mattf
Level V
