noodles
Community Trekker
Simple Histogram
Hi all,
Here is my code. I was attempting to make a histogram using one of the sample files included with JMP.
dtA = Open("C:\Program Files\SAS\JMP\9\Support Files English\Sample Data\Students1.JMP", Invisible);
histogram = (dtA << Distribution(
                              Nominal Distribution( Column(:age) ),
                              Where ( :sex == "M"),
                              Invisible
close (histogram, save("histogram_students.jrp"));
Here is the error I get:
The file cannot be opened for writing, opening for reading only.
invalid argument{233}
in access or evaluation of 'Close' , Close( histogram, save( "histogram_students.jrp" ) )
Any help would be great. Thanks!
pmroz
Re: Simple Histogram
The close function in this context is for datasets.  You have a graphical object you're trying to save.  This code will work, but it saves to a MS Word file, not a JRP file:
dtA = Open( "$sample_data\Students1.JMP", Invisible );
      Nominal Distribution( Column( :age ) ),
      Where( :sex == "M" ),
      Invisible
histogram << save msword("", native) ;
histogram << close window();
close(dta, nosave);
pmroz
      Invisible
close(dta, nosave);
noodles
Community Trekker
Thanks PMroz!
I used this line to save it as a png instead:
histogram << save picture("", png);
