BookmarkSubscribeRSS Feed
mws
Oct 10, 2012
Significance of p-values for Sign test for paired results
I'm comparing detection frequency of analytes in 150 paired stream samples using two different analytical methods. The results are provided in two columns with concentration reported for each method in ng/L. Nondetections are reported as <RL where RL is the reporting level. I've recoded the results with a 0 for a nondetection and a detection as a 1. I used the matched pair platform (jmp 9.0.3) to compare differences in detections.
We want to know whether one method has significantly more detections than the other method by analyte. I planned to use the non-parametric sign test because we only want to compare detections. The results for one analyte are shown below. The mean difference shows there are about 10 more detections (0.0667 x 150) in 2437 than in 2033 method.
1)  The sign test p-value for 2-sided test is not significant (Prob ≥ |M| 0.0755), while the one-sided test is (Prob ≤ M 0.0378). Also the sum of the one-sided p-values does not equal 1, as in the case of the t-test. Can this be correct?
2) Is there a reference or any information on the Test Statistic M?
3) Is the sign test rather than the t-test or Wilcoxon signed rank test the best approach with all data either 0 or 1? Any suggestions on a better way to do this analysis?
Matched pairs:
Difference: detection2033-detection2437
detection2033 0.18667 t-Ratio -1.98016
detection2437 0.25333 DF 149
Mean Difference -0.0667 Prob > |t| 0.0495
Std Error 0.03367 Prob > t 0.9752
Upper 95% -0.0001 Prob < t 0.0248
Lower 95% -0.1332
N 150
Correlation 0.50774
Sign Test
Test Statistic M -5.000
Prob ≥ |M| 0.0755
Prob ≥ M 0.9855
Prob ≤ M 0.0378
Wilcoxon Signed Rank
Test Statistic S -67.500
Prob>|S| 0.0476
Prob>S 0.9762
Prob<S 0.0238
