BookmarkSubscribeRSS Feed
senatorx
Jun 12, 2012
Show the Line of an Error with Throw()
Hey,
I'm trying to handle some unavoidable errors with Try and Throw.  Looking at Throw in the Index it says:
Throw("text")
Function
Returns a Throw. If you include text, throwing stores text in a global exception_msg. If text begins with "!", throwing creates an error message about where the exception was caught.
So I tried this to get the error line:
try(abcdef;
      throw("!nice error.");
show(exception_msg);
This doesn't seem to work as intended, since it doesn't show the line that created the error or give a line number.  It sounds like the info is stored in exception_msg, but script execution halts after the throw, so I cannot display it.
Has anyone had success with getting the line that caused the error?
senatorx
Jun 12, 2012
Re: Show the Line of an Error with Throw()
I believe I've figured it out - the Throw has to be contained within a function so that script execution will continue outside of the function:
doMath = Function({a,b,c}, {Default Local},
      ::result = a*b*c;
           Try(
                 abcde;
                 Throw("!nice error.");
show(result);
and I get from the log:
exception_msg = {"Name Unresolved: abcdef"(1, "abcdef", abcdef)};
Is there any way to get an actual Line Number?  It could get quite messy trying to find where that line is located!
