Dongjin
Show '%' on mosaic chart
Hello, everyone.
Now I'm using JMP 14.2 (I can't use version 15 because it's a special situation. (Only 32bit versions are available.))
I'm inquiring about something while using it.
When Mosaic Chart is drawn using Graph builder,
If you select 'Cell-Labeling (as Show Percents), only the number is currently displayed on the chart.
Can I set the unit '% sign' on this?
Re: Show '%' on mosaic chart
The '%' formatting for Mosaic was added in JMP 15.0, but I'm not aware of a workaround to change the formatting in JMP 14.
Dongjin
Thank you for answering my inquiry quickly.
It was an inquiry from my team member, and I think I can deliver it clearly.
Thanks again.
