Should you Loop through a data table or use Recode, or use Get Rows Where to change values in a data table
A recent Community Discussion script to find and replace a numeric value with a missing value in the whole tablehad a very nice entry provided by @SDF1 that was selected as the solution
names default to here(1);
dt=current data table();
For( i = 1, i <= N Rows( dt ), i++,
	For( l = 1, l <= N Cols( dt ), l++,
		If( Column( l )[i] == 999,
			Column( l )[i] = .
When I viewed the solution, an old teaching popped into my brain that roughly stated is, "Don't loop through a data table.  Looping is slow. Use the JMP built in capabilities."
So I started out to modify @SDF1 code.
I determined that my fallback standard of "Get Rows Where()" would be faster.  After all, it allows all found rows to be set with one assignment statement, after the "very fast" Get Rows Where() has found the rows.
Another solution, that I have seen pushed recommended by the community is the Recode facility in JMP.
So:
Hypothesis: The built in JMP functions of Get Rows Where and Recode will be faster than Looping down and across an entire data table.
I selected the Semiconductor Capability data table as a good sized table, 132 columns and 1455 rows
I wrote a little script that sets 10 random values in each column to 999.
for(i=5,i<=ncols(dt),i++,
	if(col stddev(ascolumn(dt,i))!=0,
	for(k=1,k<=10,k++,
		column(dt,i)[randominteger(1,1455)]=999;
dt = Current Data Table();
start = HP Time();
For( i = 5, i <= N Cols( dt ), i++,
	dt << Recode Column(
		As Column( dt, i ),
		{If( _rcNow == 999, ., _rcNow )},
		Target Column( As Column( dt, i ) )
show(hptime()-start)
This is the original value to be changed in the Discussion  mentioned above.  The 999 is to be changed to missing (.) by the scripts.
Method:
  1. Startup JMP 16.
  2. Read in the Semiconductor Capability data table
  3. Run the script to set the 999 values in each column
  4. Repeat the above 2 steps for each of the 3 methods and recode the time down to the millisecond.
  5. Repeat the above steps for JMP15
Here is the script for the Recode
start = HP Time();
		As Column( dt, i ),
The code for the Get Rows Where
start=hptime();
for(i=5,i<= ncols(dt),i++,
	column(dt,i)[dt<<get rows where(ascolumn(dt,i)==999)]=.;
	if(mod(i,10)==0,show(i));
And here are the surprising results
The For Loop wins hands down.  And from the results, the Get Rows Where should be used sparingly.
Comments and corrections are welcomed......
22 REPLIES 22
hogi
Level XIII
Re: Should you Loop through a data table or use Recode, or use Get Rows Where to change values in a data table
hi @ron_horne , the problem is with the get rows where, so speed should be/ is independent of such settings.
On the other hand, it makes a huge difference if the column index is explicit or if it's a variable (even if the variable has an assigned value).
This was not clear to me - how good that I found this conversation!
I don't know how many jsl codes out there could be faster by a factor of ~ N(rows of data table)  ...
Can the issue be fixed  by what goes on in the background of JSL?
Or is there a fundamental something in the JSL architecture which specifies that such a behavior is intended and cannot be changed?
If so: a warning message could help coders not to be trapped by this issue ...
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
For( k = 1, k <= 4, k++,
	dt << Concatenate( dt, dt, dt, Append to first table )
nuke = Function( {},
	For( k = 1, k <= 10, k++,
		Column( dt, 5 )[Random Integer( 1, 1455 )] = 999
//dt << show window(0);
//dt<< Begin Data Update();
nuke();
start = HP Time();
i = 5;
dt << get rows where( As Column( dt, i ) == 999 );
Show( (HP Time() - start) / 1000000 );
nuke();
start = HP Time();
dt << get rows where( As Column( dt, 5 ) == 999 );
//dt << End Data Update();
hogi
Level XIII
Hm, perhaps it's possible to switch JSL to a user-friendly mode (which pre-evaluates variables if this leads to better performance)?
wish: get rows where: speed issue
If a user is aware of the issue, a very cheap solution is to add an Eval():
start = HP Time();
dt << get rows where( As Column( dt, Eval(i) ) == 999 );
Show( (HP Time() - start) / 1000000 );start = HP Time(); i = 5; dt << get rows where( As Column( dt, Eval(i) ) == 999 ); Show( (HP Time() - start) / 1000000 );
hogi
Level XIII
@hogi wrote:
If a user is aware if the issue, a very cheap solution is to add an Eval()
cheap regarding complexity of the JSL code vs. time penalty.
But for longer tables Eval(i) loses signifantliy agains Substitute(... ,NameExpr(As Column()))).
So: still quite fast (compared to the original version :), but not as fast as I would have expected.
Why? What's the fundamental difference?
