japierce
Shifting a the control treatment in graph builder
I tried shifting treatments on the x axis of graph builder. I want the control first on the x axis but when I tried a few options for shifting locations the only ones that put the control where I wanted it moved other treatments which are paired.
Re: Shifting a the control treatment in graph builder
If possible, please share an image of your graph.  Also, what version of JMP are you using?  This sounds like something you could fix with value ordering.
japierce
JMP14Pro. I tried a graph separately. Thanks!
gzmorgan0
As @bill_worley stated, I think you need Value Ordering  try this script
Names Default to Here(1);
bc_agegrp = Open("$Sample_data/Big Class.jmp");
//Add a new column Age Group
bc_agegrp  << New Column("Age Group", character);
:Age Group << Set Each Value(If(
	:age < 15, "Younger",
	:age < 16, "Middle",
	"Older"
gb1 = Graph Builder(
	Size( 534, 450 ),
	Show Control Panel( 0 ),
	Variables( X( :Age Group ), Y( :weight ), Color( :Age Group ) ),
	Elements( Box Plot( X, Y, Legend( 6 ) ), Points( X, Y, Legend( 7 ) ) ),
		Dispatch(
			"400",
			LegendBox,
			{Legend Position( {6, [0, 1, 2, 3, -3], 7, [-1, -1, -1]} ),
			Position( {0, 1, 2, 3, -3, -1, -1, -1} )}
report(gb1)[OutlineBox(1)] << set Title("No Value Ordering");
Wait(3);
//-----Value Ordering-------
:Age Group << Set Property("Value Ordering", {"Younger", "Middle", "Older"});
To do this by using the point and click:
  • select the column you want to reorder
  • right click and select, Column Properties, then Value Ordering
  • Move the values up and down to the order you want and press OK
