Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
LimVitamed
Shelf life prediction
Hey everyone,
There is any way to estimate the shelf life of a pharmaceutical product based on historical data of other batches by giving only one result?
The goal is to predict, based on the primary result, if a product will survive until its expiry date.
Thanks in advance.
David_Burnham
Re: Shelf life prediction
"There is any way to estimate the shelf life of a pharmaceutical product based on historical data of other batches"
- Yes, you can use the degradation platform to perform stability analysis  (JMP applies ICH guidelines in the estimation).  You'll find it under the menu option Analyze>REliability and Survival.
" by giving only one result? "
- What do you mean by this?
-Dave
LimVitamed
Thank you for your help. Can I use Historical data of batches that have reached the end of their shelves-life in order to estimate whether a certain batch will reach the end of its shelve life? and if there's any way to change the calculated weight of each batch based on its stability stage? Lim.
JPTPHARMA
Re: Shelf life
we want to self life excel sheet
Re: Shelf life
JMP can open Excel spreadsheets directly.  Just go to
     File==>Open
If your spreadsheet is not just in a simple row and column structure, you can specify to use the Excel Wizard to input the spreadsheet.  Just Navigate to the spreadsheet file, select the file of interest, and then using the dropdown arrow on the "Open" button, select "Use Excel Wizard"
Once the table is open, you can rn your stability analysis.
Re: Shelf life
Article Labels
