tnad
Sharing model profiler results within company
I'm trying to figure out the best way I can share a model of process data with operators at a plant who do not have JMP. I know the easiest way is to use the profiler and save an interactive html that they can use to manipulate the factors and check the response. The problem is standard errors on predictions disappear when I convert to html. Is there a prefered way to do this? maybe in excel? I've been using JMP pro for over a year at my company and we always hit this wall when we try to share and apply our analysis to real operations.
Re: Sharing model profiler results within company
Currently the standard errors on predictions are not implemented for the Interactive HTML profilers.  Can you provide more information about what platforms you use to model process data?
Nazarkovsky
In 2020, the same issue emerges even in the 15th version of JMP, unfortunately.
Reaching New Frontiers
