Theresa
Several questions about data table column value update, thanks
//1.how to realize if age<12, then change :age value to "small", other value in :age keep no change
//2.how to realize that add "-ABC" to :name to let the whole column change to for example "KATIE-ABC"
//then how to realize that split the :name by "-" , remove the letters after "-""
//3. how to realize if :height>60, and weight has value !=blank, then age value change to "Yes", other value in age keep no change.
Re: Several questions about data table column value update, thanks
// value to "small", other value in :age keep no change
names default to here(1);
dt << set name("Example 1a");
// Use the Value Labels column property to change the
// displayed value, while not changing the actual value
dt:age << set property("value Labels", {12 = "small"});
dt << Oneway( x(:age), y(:height));
dt << set name("Example 1b");
// Change the actual value of 12 to "small"
// Since the column Age is a numeric column, it will
// have to be changed to Data Type Character before
// the value can be changed
dt:age << data type(character);
// Now the vlaue can be changed
// The age value in  :age == "12"  has to be in
// double quotes, since the age column has been
// changed to data type character
dt:age[dt<<get rows where(:age == "12")] = "small";
// A For Each Row() loop could also have been used to
// change the value
/*For Each Row(
	If( :age == "12", :age = "small")
// to let the whole column change to for
// example "KATIE-ABC"
//then how to realize that split the :name by "-",
// remove the letters after "-""
dt << set name("Example 2");
// To add the characters to each value of :Name
// just requires a simple For Each Row() with
// a concatenation of "-ABC" to each value
For Each Row(
	dt:Name = dt:Name || "-ABC"
// To find the "-" and to get rid of the "-ABC"
// is easily done with a Word() function
// It allows one to parse strings into "words"
// based upon designated delimiters
For Each Row(
	dt:Name = Word(1, :Name, "-" )
// The removal of the values after finding the
// "-" can also be accomplished using either
// a Left() function or a Substr() function
// using the returned value from a Contains()
// function to determine where the "-" is
/*For Each Row(
	dt:Name = left(dt:Name,contains(dt:Name,"-") -1 )
// or
For Each Row(
	dt:Name = Substr(dt:Name,1, contains(dt:Name,"-") -1 )
// has value !=blank, then age value change
// to "Yes", other value in age keep no change.
dt << set name("Example 3");
// Set the value of JACLYN's weight to missing
// to allow for the test case, where the
// :Height is greater than 60, but the :Weight
// is missing
dt:Weight[4] = .;
// Since the column :height is numeric and a
// character value of "Yes" is to be placed in
// that column, the column needs to be changed
// to Data Type of Character
dt:Height << data type(character);
// Now a For Each Row() with a two level
// comparison can be used to change the
// described value
For Each Row(
	If( :Height > "60" & isMissing( :Weight ) == 0,
		:Height = "Yes"
// change the value
/*For Each Row(
For Each Row(
For Each Row(
/*For Each Row(
// or
For Each Row(
// is missing
dt:Weight[4] = .;
// described value
For Each Row(
		:Height = "Yes"
Theresa
thank you so much. all are work, only the last one can't work, i initiative a new ticket, and put the pic in the discussion, could you help check ? May peace with you.
