BookmarkSubscribe
pmroz
Set values of number col edit box?
I can't seem to set values for a number col edit box, separately from when it's created.
nw = new window("test",
        tablebox(
            neb = numbercoleditbox("Numbers", {}),
            teb = stringcoleditbox("Strings", {}),
a = {1, 2, 3, 4, 5};
b = {"a", "b", "c", "d", "e"};
neb << set values(a);
teb << set values(b);
This code results in:
I need to add dynamically add numbers outside of window creation.
pmroz
Re: Set values of number col edit box?
Aha found it - using SET instead of SET VALUES does the trick.  Not obvious.
