BookmarkSubscribe
mjoner
Set to Data in Row - change profiler AND simulator means/constants?
I'm working with a Profiler with the Simulator on.
I've just tried to send a Set to Data in Row message to the Profiler, using code like this:
dt = Current Data Table();
profiler = dt << Get Property("Profiler");
prof = Eval(profiler);
prof << Simulator(1);
selrow = (dt << Get Selected Rows())[1];
Eval(Substitute(Expr(prof << Set to Data in Row(__r__)),Expr(__r__),selrow));
I am seeing that the Profiler does set itself to the selected row, but I am not seeing corresponding changes in the Simulator constants (or means if I change them from Fixed to Random). How can I impact both?
