pmroz
Set Title of App Builder Module?
I have an application builder module in JMP 12 and I want to set the window title.  The top-level module variable name is my_search.  In the script section I'm trying this:
my_search << set window title("Hello world");
But it doesn't set the title.  The scripting index shows examples but they all involve opening the .jmpappsource file.  I'm already in that file; how do I set the window title?
Thanks,
Peter
pmroz
Re: Set Title of App Builder Module?
One of my colleagues had the answer in a course book:
(thismoduleinstance << get box) << Set Window Title ("Hello world");
pmroz
You can also send the <<SetWindowTitle message to any display box contained within the module.  This is the best approach if you want to set the title dynamically.
If you have a static title, you can use the property editor in App Builder by selecting the module and changing the 'Title' property.
Article Labels
