Adam_Xu
Set Spec Limits of columns with column stored value
Hi All,
I imported csv files into JMP to get data table (assigned as dt0) and spec table (assigned as dt1) respectively. I wonder to get the spec in spec table (dt0) and set Spec Limits of columns in data table (dt0).
The issue I found that the specs can not be set successfully:
Here are my codes:
Files = Pick File(
"Select CSV File",
"$Downloads",
{"JMP Files|jmp;jsl;jrn", "All Files|*"},
1,
0,
dt0 = Open(
Files,
Import Settings(
End Of Line( CRLF, CR, LF ),
End Of Field( Comma, CSV( 0 ) ),
Strip Quotes( 1 ),
Use Regional Settings( 0 ),
Scan Whole File( 1 ),
CompressNumericColumns( 0 ),
CompressAllowListCheck( 0 ),
Labels( 1 ),
Column Names Start( 2 ),
Data Starts( 8 ),
Lines To Read( "All" ),
Year Rule( "20xx" )
dt1 = Open(
Files,
Import Settings(
Strip Quotes( 1 ),
Labels( 1 ),
Data Starts( 5 ),
Lines To Read( 2 ),
Year Rule( "20xx" )
For(i=13, i<=N Cols(dt0), i++,
Column(dt0,i)<<Data Type(Numeric);
Column(dt0,i)<<Modeling Type("Continuous");
For(i=13, i<=N Cols(dt1), i++,
Column(dt1,i)<<Data Type(Numeric);
Column(dt1,i)<<Modeling Type("Continuous");
tempUSL=Col Stored Value(dt1, i, 1);           //Assign the spec from dt1 spec table to 'tempUSL' and 'tempLSL'
tempLSL=Col Stored Value(dt1, i, 2);
Eval(
Eval Expr(
Column( dt0,i ) << Set Property(
"Spec Limits",
{LSL( Expr( tempLSL ) ), USL( Expr( tempUSL ) ), Show Limits( 1 )}
Any advice to address this issue? Thanks
Adam_Xu
Re: Set Spec Limits of columns with column stored value
Hi All,
I found the solution by using these codes:
Eval(
		Eval Expr(
			tempUSL=Col Stored Value(dt1, Expr(i), 1)
	Eval(
		Eval Expr(
			tempLSL=Col Stored Value(dt1, Expr(i), 2)
Thanks
Adam_Xu
If assign a number to 'tempUSL' and 'tempLSL' directly, it could work.
But I need to assign the spec limits from spec table.
Files = Pick File(
	"Select CSV File",
	"$Downloads",
	1,
	0,
dt0 = Open(
	Files,
	Import Settings(
		Strip Quotes( 1 ),
		Labels( 1 ),
		Data Starts( 8 ),
		Year Rule( "20xx" )
dt1 = Open(
	Files,
	Import Settings(
		Strip Quotes( 1 ),
		Labels( 1 ),
		Data Starts( 5 ),
		Lines To Read( 2 ),
		Year Rule( "20xx" )
	tempUSL=0.74;
	tempLSL=0.56;
	tempTarget=(tempUSL+tempLSL)/2;
	Eval(
		Eval Expr(
				"Spec Limits",
Adam_Xu
Hi All,
Eval(
		Eval Expr(
	Eval(
		Eval Expr(
Thanks
Byron_JMP
I see what you're doing and I have to say your code looks very nice. Also very complex.
There are several other ways to get the same thing accomplished by scripting platforms that already exist in JMP.
Here are are a couple of examples:
This one uses the process screening platfom
dt1 = Open( "$SAMPLE_DATA/Cities.jmp" );
dt2 = Open( "$SAMPLE_DATA/CitySpecLimits.jmp" );
dt1 << Process Screening(
	Y( :OZONE, :CO, :SO2, :NO ),
	Use Limits Table(
		1,
		dt2,
		Process Variables( :Column 1 ),
		LSL( :_LSL ),
		USL( :_USL ),
		Target( :_Target ),
		Go
This one uses the process capability platform
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = dt << Process Capability(
	Process Variables( :OZONE, :CO, :SO2, :NO ),
	Spec Limits(
		Import Spec Limits(
In this example, a dialog opens to allow the user to select the spec limit table
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
obj = dt << Manage Spec Limits(
	Y( dt << Get Column Group( "Processes" ) )
This basics code which takes advantage of platform features, is much easier to maintain too.
Hope this was useful,
Cheers,
B
Adam_Xu
Very good advice, it really helps. Thank you very much, Byron!
