uday_guntupalli
Level VIII
Set Platform Preferences using a variable
All,
     I am trying to set platform preferences dynamically based on User Input collected using a UI.
     Essentially, the user specifies which Matlab version is installed on their machine and I am using that to construct a 32-bit and a 64-bit path to the root variable for Matlab on the users machine.  However, this repeatedly results in an error:
Unexpected "\MATLAB\R2018a\". Perhaps there is a missing "," or ")".
Trying to parse arguments of function "MATLABROOT32".
        Any help or advice is appreciated.
user_matlab_ver = '2018a' ; // for example
matlab_32bit_path = "C:\Program Files (x86)\MATLAB\R2018a\"; matlab_64bit_path = "C:\Program Files\MATLAB\R2018a\"; Eval( Parse( Eval Insert("\[ Platform Preferences( PathVar( MATLABROOT32( ^matlab_32bit_path^ ), MATLABROOT( ^matlab_64bit_path^ ) ) );]\" ) ) ); ConnectToMatlab = Expr( matlab_conn = MATLAB Connect(); matlab_conn_flag = matlab_conn << Is Connected; ); ConnectToMatlab;
Best
Uday
uday_guntupalli
Level VIII
Re: Set Platform Preferences using a variable
Thanks to @gblatz , the following works:
Eval(
	Parse(
		Eval Insert(
				" Platform Preferences( PathVar( MATLABROOT32( \!"^matlab_32bit_path^ \!" ), MATLABROOT( \!"^matlab_64bit_path^\!" ) ) );"
Best
Uday
uday_guntupalli
Level VIII
Eval(
	Parse(
		Eval Insert(
Best
Uday
vince_faller
The issue you had with the quoted strings is one of the reasons I usually prefer Eval(Substitute()) or Eval(EvalExpr())
Eval(
	Substitute(
		Expr(
				PathVar(
					MATLABROOT32( "DV_ML32" ),
					MATLABROOT( "DV_ML64" )
		"DV_ML32", matlab_32bit_path,
		"DV_ML64", matlab_64bit_path
Vince Faller - Predictum
