teresa
Send several graphs to PowerPoint
I have a data table with several graph's script. I run all of them and I get each graph in a new window. Now I'd like to send all graphs to PowerPoint. Can I do it at a time?
Re: Send several graphs to PowerPoint
I had a similar requirement and this is what i did. I autoamted the JSL using VB and then produced the plots and saved them using save picture command. Once the graphs are created the VB script invokes the powerpoint application and creates the powerpoint presentation. Let me know if you need more details on this.
teresa
Thanks Nixs,
It is a good idea. I will try it, at least saving Pictures from JMP. The VB script to invokes them to powerpoint is out of my knowlege.
Hi Nixs,
I am interested in know more detail on how you pass the graph to powerpoint using VB script. I usually use VB script to call JMP and run JSL file to generate the graph. Please give me more detail from finish generate graph to save to powerpoint, and if possible some sample code. Thanks very much.
