fuscod
Selection of Data
I need to select all rows in at data set that meet this criteria:
CT<<Select Where ( (Is Missing (:Last Name)));   Note this is OK and not a problem.
The challenge I am having is I then need to DESELECT rows that meet the following criteria:
(  (is Missing (:Last Name) & Object Type == "NWA"  &  :Amount > 0)  )
This all seems simple enough but I've spent a couple of hours trying to figure it out!
Thanks,
Dan F.
7 REPLIES 7
ms
Super User ms
Re: Selection of Data
CT << select where(Is Missing(:Last Name) & !(:Object Type == "NWA" & :Amount > 0));
ian_jmp
The editor tooltips can be very useful in cases like this:
By using the second parameter in 'Select Where' you should be able to get what you want:
NamesDefaultToHere(1);
// Selects all males
dt << SelectWhere(:sex == "M");
wait(1);
// Deselects males who are 14
dt << SelectWhere(:age != 14, currentSelection("restrict"));
(I'm using JMP 12, BTW).
fuscod
JMP User Community – Thank you for your assistance on the JMP questions. I have another question for the User Community.
I am joining two jmp data tables by “Charge No” that originated from generic SAP Reports. The challenge is that:
· In Data Set A the “Charge No” data is: six numbers + 1 SPACE + four numbers
o For example: 141922 0010
· However in Data Set B“ Charge No” data is: six numbers + 7 SPACES + four numbers
What I would like to do and my new question is how to write the jmp script that will modify Data Set B so that the configuration of “Charge No” the same as in Data Set A. i.e. six numbers + 1 SPACE + four numbers
Hi, Dan.
Regarding your spacing issue...  The Collapse Whitespace() function became available in JMP 11.  The following will eliminate duplicate spaces within the values located in the Charge No column.
dtb = Data Table( "Data Set B" );
For Each Row(
     Column( dtb, "Charge No" )[Row()] = Collapse Whitespace( Column( dtb, "Charge No" )[Row()] )
Hope that helps!
Wendy
Wendy
fuscod
Thank you for this information – please see below for continuation of these questions:
1. For the condition (Is Missing(:Last Name) & Type == "NWA" & :Amount = $800)
I’d would like to populate the character column :Last Name == “Vertek Invoice”
2. And for condition (Is Missing(:Last Name) & Type == "NWA" & :Amount = $157,736)
I’d would like to populate the character column :Last Name == “LV2 PIN06/07”
Thank you,
Dan
Daniel Fusco
Project Manager
BWR In-Vessel Modifications and Repair
Westinghouse Electric Company
226 Airport Parkway, Suite 595
San Jose, CA 95110-3740
phone: +1 (408) 392-7455
cell: +1 (408) 202-3601
fuscod@westinghouse.com<mailto:fuscod@westinghouse.com>
pmroz
dt = New Table( "Test Table", Add Rows( 6 ),
     New Column( "Last Name", Character, Nominal,
           Set Values( {"", "", "", "", "aaa", "bbb"} )
     New Column( "Type", Character, Nominal,
           Set Values( {"NWA", "NRA", "NWA", "NBA", "NWA", "NWA"} )
     New Column( "Amount", Numeric, Continuous, Format( "Best", 12 ),
           Set Values( [800, 800, 157736, 157736, 800, 157736] )
v_rows = dt << get rows where(Is Missing(:Last Name) & Type == "NWA" & :Amount == 800);
if (nrows(v_rows) > 0,
     column(dt, "Last Name")[v_rows] = "Vertek Invoice";
l_rows = dt << get rows where(Is Missing(:Last Name) & Type == "NWA" & :Amount == 157736);
if (nrows(l_rows) > 0,
     column(dt, "Last Name")[l_rows] = "LV2 PIN06/07";
fuscod
Thanks!
