Françoise
Selection filter in sql query builder with JMP14
I have a sql query builder with a selection in the filter like this:
then I save the sql query builder and close it.
Wen I open it, I have the filter with this selection retained:
 It means that the filter doesn't want to select a word written upper-case and lower-case. only one is selected.: in this exemple the lower-case.
How to have the two forms?
Jeff_Perkinson
Re: Selection filter in sql query builder with JMP14
This looks like a bug in the Query Builder. I'll report it and we'll try to address it in a future maintenance release.
Unfortunately, I can't find a workaround at the moment.
I'll keep looking at it, but perhaps another community member will have an idea.
-Jeff
Françoise
Thanks for your answer.
How long to have this pb solved by the support?
best regards
Françoise
It's a big problem: when you have big excel files, the excel filter of the columns doesn't make the difference bettween the 2 forms.
