teresa
Community Trekker
Select rows included in a list
I have a list like VAR={"P1", "P3", ...}
My Data Table have a column ("Variable") whose content are P1 or P2 or P3 or ...
example:
Row Variable Response
1 P1 3
2 P2 5
3 P3 7
I would like to say JMP to select rows whose :Variable's value are include in the list VAR. In my example I would like to select rows 1 and 3 because their values match with one of the values of the list.
Can anyone help me?
Thanks,
Teresa
mattf
Community Trekker
Re: Select rows included in a list
//Here's one way that I think does what you want
// list of desired ages
myAgeList = List( 14, 15 );
// is the row a match for out list?
// row 3, (Jane) is 12, so no
Loc(myAgeList, :age[3])==[] ; // []=no
// row 17, (Elizabeth) is 14, so yes
y = Loc(myAgeList, :age[17]); // 1=yes 1st item in the list
// selectively select & color them
For Each Row(
If(Loc(myAgeList, :age)>=1,
ColorOf(Row state(i)) = 3; // change color to red for row i
Selected(Row State(i)) = 1; // select the desired rows
// Best regards,
// Matt
mattf
Community Trekker
// Oops, forgot the iterator
For(i=1, i<=n Rows(dt), i++,
teresa
Community Trekker
Thanks Matt,
You have give me a good solution.
Following your idea, I have tried with this:
for each row (if(contains(VARS,:Lineas)>0, Row State()=selected state(1) ));
(VARS is the list and :Lineas de Column I would like to compare)
It seems it works, and I do not need to use the iterator.
Best regards,
Teresa
