Sburel
Select only tables which contain a specific string in the table to use as variable
I'm trying to concatenate a bunch of tables that are generated iteratively by a process.
The name of  those tables all start with the same prefix.
I can easily concatenate all the open tables but I'm unable to find the correct syntax to only concatenate those tables with a specific prefix and leave the other ones alone.
Any suggestions?
Best
Sebastien
//The first script to concatenate only tables with 'Pvalue' in the name  fails
//But the dtLIst does shows the correct list of tables BUT list them without the 'data table' prefix.
// as a result, the concatenation step does not interpret them as a list of table
clear log();
try(data table("LogP")<<close window,"");
dx=new table("LogP");
c = "Pvalues ";
dtLIst = {};
For( i = 1, i <= N Table(), i++,
	dt = data table(i)<<get name;
	if(contains(eval(dt),c),
	insert into(dtLIst, dt ))
print(dtLIst);
data table("LogP")<<concatenate(data table (dtLIst}),"Append To First Table");
//This scripts to concatante all the table works
//Shows the list of table with the 'data table' prefix
try(data table("LogX")<<close window,"");
dx=new table("LogX");
dxLIst = {};
	dt = data table(i);
	insert into(dxList, dt );
print(dxLIst);
data table("LogX")<<concatenate(eval(dxLIst),"Append To First Table")
Re: Select only tables which contain a specific string in the table to use as variable
The structure of what dt is has changed, so the contains needs to be changed to
contains(uppercase(dt<<get name),uppercase(c))
6 REPLIES 6
I can not see anything inherently wrong.....but you could be having a upper/lower case issue  try
If(contains(uppercase(dt), uppercase(c),
Sburel
Hi Jim,
Thanks for the quick reply. I've tried you fix to no avail.
Here is the Log I get when I implement my script:
dtLIst =>
"{"Pvalues PBS vs PBS", "Pvalues PBS vs 741039", "Pvalues PBS vs 740410", "Pvalues PBS vs 709966", "Pvalues PBS vs 709878", "Pvalues PBS vs 709573", "Pvalues PBS vs 709547", "Pvalues PBS vs 709544"}
Cannot locate data table in access or evaluation of 'Data Table' , Data Table/*###*/(dtLIst)
at line 19 in C:\Users\sburel\Ionis\Neurology Research - Documents\Core\Neurotoxicology\Miscellaneous Research Activities\DATABASE ALL CNS DATA\Associated scripts\intermediate and toy scripts\Toy example to concatenate multiple tables with a specific string in nam.jsl "
If I use the next part of the script, here's the Log I get for dxLIst=>
"{DataTable("LogX"), DataTable("LogP"), DataTable("Pvalues PBS vs PBS"), DataTable("Pvalues PBS vs 741039"), DataTable("Pvalues PBS vs 740410"), DataTable("Pvalues PBS vs 709966"), DataTable("Pvalues PBS vs 709878"), DataTable("Pvalues PBS vs 709573"), DataTable("Pvalues PBS vs 709547"), DataTable("Pvalues PBS vs 709544"), DataTable("NT191209 7-DGE in vivo mouse single stacked")}"
The second list gets concatenated just fine but included tables I don't want. The first list (dtLIst) does not contain  the  "Data table ("xyz").
I suspect that I'm not using the proper syntax to tell the script to evaluate each items in the first list as a data table.
//This script to concatenate only table with 'Pvalue' in the name  fails
clear log();
c = "Pvalues ";
dtLIst = {};
	if(contains(uppercase(dt),uppercase(c)),
print(dtLIst);
data table("LogP")<<concatenate(data table (dtLIst),"Append To First Table");
//This scripts to concatenate all the tables works
dxLIst = {};
	dt = data table(i);
print(dxLIst);
Maybe you'll be able to see the errors of my way :)
Thanks
Sebastien
I apologize, I thought your issue was in building the dtLIst.  The issue is slightly different.
The issue lies in providing to the Concatenate Platform the proper information.  The structure of the Concatenate Platform's required input is
Data Table() << concatenate( data table(), data table()…., Append to first table(1) );
What you are passing to Concatenate is:
Data Table( "LogP" ) << Concatenate( Data Table( {"Pvalues PBS vs PBS", "Pvalues PBS vs 741039", "Pvalues PBS vs 740410", "Pvalues PBS vs 709966", "Pvalues PBS vs 709878", "Pvalues PBS vs 709573", "Pvalues PBS vs 709547", "Pvalues PBS vs 709544"} ), "Append to first table" )
The primary issue is that each of the data table names you have, need to be changed to the format of Data Table( "...….." )
This can be done with two small changes.
First, change the structure of your dtLIst.  You don't want just the data table name, but the whole structure
	dt = data table(i);
Next, the Concatenate statement becomes
data table("LogP")<<concatenate( dtLIst,  Append To First Table(1));
Sburel
No need to apologize! I was probably not very clear in the first place.
Anyway, we must be close but the construction of the dtLIst is not working. I tried with with and without uppercase to no avail
Here's the log from the run:
argument should be character in access or evaluation of 'Uppercase' , Bad Argument( dt ), Uppercase/*###*/(dt)
So close, yet so far...
Here's my current code
clear log();
c = "Pvalues ";
dtLIst = {};
	dt = data table(i);
print(dtLIst);
data table("LogP")<<concatenate(dtLIst, Append To First Table (1));
Sburel
That did the trick!
Thank you so much.
Best,
Sebastien
