BookmarkSubscribe
ptkguy
Select any item from a list
JMP 8.0.2.2 on Windows XP
I have a data table where I would like to select all the rows that contain any values from a stored list. Is there some simple built-in function to do this or will I have to use some sort of messy for loop?
Sample Script:
dt=current data table();
temp = {"a","b","c"};
dt<
mpb
Super User mpb
Re: Select any item from a list
Look up the "contains" function in the pdf scripting docs installed with JMP. That function will do what you want.
