I often find that the Contains() function inside the Select Where() function can be convenient. What if I would like to select all rows where a designated column contains the string "a" when it is followed by a number? For example, in a column with the values "a", "a12", and "absent", only the row with "a12" would be selected. Thanks for any tips!
