BookmarkSubscribeRSS Feed
robot
Feb 27, 2012
Select Columns - JMP10
I am having trouble selecting columns in JMP10.  This example is lifted strait from the JMP10 Scripting Guide:
cc = dt << Get Column Names( Continuous );
ncols = N Items( cc );
For( i = 1, i <= ncols, i++,
  cc << Set Selected( 1 )
However, it generates the following error in the log:
Send Expects Scriptable Object in access or evaluation of 'Send' , cc << Set Selected( 1 )
In the following script, error marked by /*###*/
  cc <<  /*###*/Set Selected( 1 ) /*###*/
Any suggestions?
Thanks!
blackeneth
Mar 6, 2013
Solution
Re: Select Columns - JMP10
Ha, if I copy your script into JMP 10.0.2 and run it, it works! Without error!
Perhaps you have multiple tables open and JMP is getting confused as to which is the 'current' one. That, or it is intepretting as a row reference.
Anyhow - ask yourself - what does variable cc contain?  It is a list, of column references.
show(cc);
cc = {height, weight};
but then run this:
show(cc[1]);
show(cc[2]);
cc[1] = :height;
cc[2] = :weight;
So your loop, is, in turn, running these commands:
:height <<  set selected(1);
:weight << set selected(1);
I think the use of the As Column(dt, name) function is clearer and more foolproof:
show (cc);
  as column(dt, cc) << Set Selected( 1 )
The following will also work:
show (cc);
  y=cc;
  dt:y << Set Selected( 1 )
blackeneth
Mar 6, 2013
Solution
show(cc);
but then run this:
show(cc[1]);
show(cc[2]);
cc[1] = :height;
cc[2] = :weight;
show (cc);
show (cc);
  y=cc;
robot
Feb 27, 2012
Thanks blackeneth,
You are correct.  My code is part of a larger script with multiple tables open and JMP was getting confused.  "As Column(dt, name)" did the trick.  Thanks!
