sornasst
Scripting: how to close an analysis within a For loop?
In the simple script below, how can I close each of the Bivariate analysis after I capture its report?
Names Default to Here (1);
dt = Current Data Table ();
m = {};
m1 = [];
m2 = [];
For (i=6, i<= N Col (dt), i++,
            bv = Bivariate(
                  Y( Column (i)),
                  X( :mRSS ),
                  Density Ellipse( 0.95, {Line Color( {213, 72, 87} )} ),
                  invisible
            bvr = bv << report;
                           insert into (m, Column Name (i));
            m1 = m1 || bvr [Outline Box (1)] [ Number Col Box (3)] [1];
            m2 = m2 || bvr [Outline Box (1)] [ Number Col Box (4)] [1];
New Table ("CORRELATION",
      New column ("Symbol", character, set values (m)),
      New column ("Correlation", numeric, set values (m1)),
      New column ("P Value", numeric, set values (m2)),
ms
Super User ms
Re: Scripting: how to close an analysis within a For loop?
bv << close window;
ms
Super User ms
bv << close window;
MS is correct, however, other issues exist in your script.  I have taken the liberty to modify your script to make it work
Names default to here(10);
m = {};
m1 = [];
m2 = [];
            bv = Bivariate(
                  Y( Column (i)),
                  X( :mRSS),
                  invisible
            bvr =report( bv );
            m1 = m1 || ((bvr [Outline Box (1)] [ Number Col Box (3)])<<get) [1];
            m2 = m2 || ((bvr [Outline Box (1)] [ Number Col Box (4)])<<get) [1];
            bv << close window;
sornasst
Hi Jim,
Thanks for cleaning up my simple script. Could you explain to me how the "<< get" command works? I noticed that my simple script worked well by simply adding the "bv << close window" command and leaving out the "<< get" command.
Also, you wrote  "Names default to here(10);" I have to admit that I have always left this command with the value 1 without thinking that it could be a larger number. What does the "10" value do to the script?
Thank you for your help.
Sincerely,
Thierry
I will first explain the "Names Default to Here(10);"  Quite simply, it is a typo.  It should be a "1".
The "<< get" is the message, when sent to the object it is pointing to, to retrieve the values.
retrieves Number Col Box(3)'s column of numbers into a list.
It is a similar to the form of retrieving the text from Outline Box(1) by specifying:
     bvr [Outline Box (1)]<<get title
Article Labels
