BookmarkSubscribeRSS Feed
Scripting errors with Save( Standardized )
Looking for some help!
I'm going to have tables with varying column counts and names.
Want a script that will run the Distribution platform on my continuous numeric columns and save the standardized columns to the table.
This script will run the Distribution platform:
dt = Current Data Table();
cc = dt << Get Column Names( Continuous );
ncols = N Items( cc );
For( i = 1, i <= ncols, i++,
cc << Set Selected( 0 )
cc << Set Selected( 1 );
Distribution( Y( cc ) );
cc << Set Selected( 0 );
...but I can't insert the Save( Standardized ) command into this script.
This script will do Save( Standardized ) on a single column:
Distribution(
Continuous Distribution(
Column( :var_2307 ),
Horizontal Layout( 1 ),
Vertical( 0 ),
... but I can't find a way to iterate this one through a column list. My attempts so far error out with "No data to analyze".
What am I missing?
Re: Scripting errors with Save( Standardized )
...but I can't insert the Save( Standardized ) command into that script.
Distribution(
Vertical( 0 ),
What am I missing?
mpb
Jun 23, 2011
This seems to work:
mpb
Jun 23, 2011
This is simpler and keeps all distribution output in a single page:
Perfect!
You are a peach.
K
