JL_LZH
Scripting: Open table and closing it
I'm new to scripting in JSL and it seems like I'm struggling right from the start..
I want to import an Excel table and then do several changes and so on. But it seems like the easiest operations doesn't work.
My idea was to start really simple: opening and closing it. I imported my Excel table with the wizard and saved the script. I altered it to the following (added a variable dt and tried closing the table:
dt = Open(
	"I:\myfile.xlsx",
	Worksheets( "mydata" ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 2 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
Close (dt);
It opens the table but it's not closing. What am I doing wrong?
Thanks in advance
ron_horne
Re: Scripting: Open table and closing it
Hi @JL_LZH
i think you have a small parentheses issue, try the following:
dt = Open(
	"I:\myfile.xlsx",
	Worksheet Settings(
		1,
Wait( 0.1 );
Close( dt );
ron_horne
Hi @JL_LZH
dt = Open(
	"I:\myfile.xlsx",
	Worksheet Settings(
		1,
Wait( 0.1 );
Close( dt );
JL_LZH
Perfect, thanks for the quick reply!
I thought I need the parantathese to end the script.... lesson learned.
