BookmarkSubscribe
jake
Scripting Column Switcher
Is there a way to script "Column Switcher"?  When I set it up for a chart and save the script, the column switcher is not saved as part of the script.
blackeneth
Re: Scripting Column Switcher
Here is an example of how to script it:
// Begin Script;
dt = Open( "$SAMPLE_DATA/Fitness.jmp" ); obj = oneway(
      Y( :Weight ),
      X( :Sex ),
      Column Switcher( :Weight,
                       {:Age,:Oxy,:Weight} ));
//End Script;
You can also find information on the JSL syntax by searching the "Scripting Index" for "column switcher".
jake
Perfect.  That's exactly what I need.  Thanks a lot.
By The Way:
I couldn't find the "column switcher" in the scripting index.
mikedriscoll
You need to search on "Objects" or "All Categories".   The scripting index won't find it if you're searching under "functions" or "display box."
