BookmarkSubscribeRSS Feed
Script the nonlinear platform to lock variables before solving
pauldeen
Oct 24, 2014
In the nonlinear platform I can supply my own equation and then ask JMP so solve the coefficients. In the visual interface I can lock some of these parameters and give them a preset value. How do I do this in scripting?
dt = Open("$SAMPLE_DATA\Big Class.jmp");
dt << New Column( "PredictorFormula",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula(
			Parameter(
				{b0 = 0.5, b1 = 0.6, b2 = 0.7},
				b0 + b1 * :height + b2 * :height ^ 2
nln = Nonlinear( Y( :weight ), X( :PredictorFormula ), By( :sex ), Newton );
Now I want to talk to nln and lock the second parameter (b1) in the first instance and change the default value to 0.55 and lock b2 in instance 2 with default value 1.
Using Xpath I'm able to select the NumberColEditBoxes and and change their values, but I cannot manipulate the lock checkmarks that way.
ValuesBoxes = nln << xpath("//NumberColEditBox/NumberColEditBoxHeader[text()='Current Value']/..");
templist = (ValuesBoxes[1] << get())[1];
templist[2] = 0.55;
ValuesBoxes[1] << set(templist);
templist = (ValuesBoxes[2] << get())[1];
templist[3] = 1;
ValuesBoxes[2] << set(templist);
I can select the checkbox column and query or set the first checkbox, but nothing more.
CheckBoxes = nln << xpath("//CheckBoxBox");
CheckBoxes[1] << get();
CheckBoxes[1] << set(1); //Only does a toggle of the first checkbox, cannot do any other checbox
Jun 22, 2012
Solution
Here is the example taken directly from the Scripting Index on locking parameters
     Help==>Scripting Index==>NonLinear==>Lock Parameter
dt = Open(
	"$SAMPLE_DATA/Nonlinear Examples/CES Production Function.jmp"
obj = Nonlinear(
	Y( :Name( "log($ value)" ) ),
	X( :Model )
obj << Set Parameter( B0 = 0.2 );
obj << Lock Parameter( B0 );
obj << Finish;
pauldeen
Oct 24, 2014
Solution
And just after I posted the question I decided to try again and I figured out how to solve it:
CheckBoxes[1] << get(2);
CheckBoxes[1] << set(2,1);
This is how you check and set the second checkbox.
Jun 22, 2012
Solution
dt = Open(
obj = Nonlinear(
	X( :Model )
obj << Finish;
pauldeen
Oct 24, 2014
That is maybe even better (certainly compacter), but does it allow to control each parameter in different levels of the by value?
pauldeen
Oct 24, 2014
Yes it does :)
Jeff_Perkinson
Community Manager
Jun 23, 2011
From the Scripting Index, the Nonlinear platform accepts a Lock Parameter message.
dt = Open( "$SAMPLE_DATA/Nonlinear Examples/CES Production Function.jmp" );
obj = Nonlinear( Y( :Name( "log($ value)" ) ), X( :Model ) );
obj << Finish;
-Jeff
pauldeen
Oct 24, 2014
Solution
