DannyORegan94
Script that has the same function as the "Open as Plain text into Script window"
I have a GUI that I have created and I want to include a Help button in my GUI. Whne the user clicks the Help button I want an instructions.txt file to be opened in a script window for the user to be able to read. I know you can do this manually when opening .txt files using option mentioned in the subject but how do I write a script to do that?
Re: Script that has the same function as the "Open as Plain text into Script window"
You just need to read the text file into a character variable, and then use the Script Box() function
string = Load Text File("C:\..............");
Script = Script Box(
	string,
	"Text",
	300,
	100
New Window( "This is a script box", Script );
	string,
	"Text",
	300,
	100
DannyORegan94
Thank you very much!!
I was not aware of the Script Box command.
