bhagbom
Script not working in JMP 11
I have a script that had been working in JMP 10 but now is not with JMP 11.  Someone else created this script so I'm learning my way through it.  The portion of the script that is causing problems is pasted below.  More specifically, I believe it is in the portion highlighted blue.  Any ideas??
ChronJoin=Function({}, //02
       //Joins data in the chronological order
       for( f = 2, f <= N Items(ShortList), f++,
           try(
               dt = open(directory || ShortList),
           /*catch*/
               print("Error 002a: Unrecognized file type "|| ShortList);
               throw();
          if(!contains(column name(1), "Date"),  //if the column name of column one is not Date
               RowRemove("Date", 1, "Time", 2);  //removes headers
               ColumnRename(ShortList);  //renames the columns
          FixRawSecondsName();
          ColumnFormat();  //sets the correct data types for the columns
          if(N Items(MultiVarCheckBox << Get Selected())!=0,
               MultiVarColumn(ShortList);
          if(N Items(HALTlinesCheckBox << Get Selected())!=0, //Verticle Reference Lines selected
               if(TestTypeRadioBox << Get()==1,  //HALT
                    HALTstages(ShortList),
               /*else if*/TestTypeRadioBox << Get()==4,
                    SAstages(ShortList);
          try(  //if dt cannot be joined, an error is printed to the log and the script is stopped
               dtPrev = dtMain;
               dtMain = dtMain << Join(
                    With(dt),
                    Merge Same Name Columns,
                    Copy Formula(0),
                    Suppress Formula Evaluation(0),
                    By Matching Columns(:Date == :Date, :Time == Time),  //joins by matching Dates and Times
                    Drop Multiples (1, 1),
                    Name("Include non-matches")(1, 1),
                    Output Table Name("Digital" || char(f), nosave);
          /*catch*/
               print("Error 002b: Failure to join "||ShortList);
               throw(); //ends current script sequence
               close(dt, nosave );  //closes the recently opened data table
               close(dtPrev, nosave);  //closes the previous data table
     while(contains(column name(1), "Match Flag"),
          dtMain << Delete Columns("Match Flag");
mpb
Super User mpb
Re: Script not working in JMP 11
I have not studied your code at all closely but I do notice that in this line:
there is no colon in front of the second reference to Time.
bhagbom
Thanks mpb for catching that.  I made the correction however that did not resolve it.
pmroz
Look in the log and tell us what the error message says.
bhagbom
The only message in the log is what the script is printing to the log.  It failing to join the two files together.  I am able to manually join the files together.
/*catch*/
pmroz
In the manually joined table, click on the little red triangle next to Source, then click Edit.  Compare that JSL code to the code you have listed here.
bhagbom
PMroz, I took your suggestion and found the difference.  It worked in JMP 10 as the following:
I am able to make it work in JMP 11 with:
     dtMain = Data Table (dtMain) << Join(
Thanks for the help!
Article Labels
