shaun
Script issue with Select/Exclude Rows
I have a script I need to add a data filter in before i run it which creates some charts. I have tried select where and exclude functions as well as the data filter script shown below:
Current Data Table() << Data Filter(
Add Filter( columns( :VRchartExcCol ), Where( :VRchartExcCol == 1 ) ),
Mode( Select( 0 ), Include( 1 ) )
I have tried iterations of the above on different columns and datasets and I cannot get the row select to work in the script. It works when running the data filter on its own outside the script and I can copy out the script from there (pasted above) but when the above is inserted and run in script either by itself or in the main script, the only functions which execute are:
Can you select and exclude rows in scripts?
Message was edited by: shaun
ms
Super User ms
Re: Script issue with Select/Exclude Rows
If you just wish to conditionally exclude rows and not really need the Data Filter window, you can set row states with the often useful function For Each Row().
For example
This script line loops through all rows and excludes rows where column Sex is not "F".
