News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
switzal87
Script for exporting capability indices as data table
Hello everyone,
Can somebody help me out to create a script that will export my capability indices report as data table. My raw data is dynamic and from time to time data changes.
What the output of the script looks like item # 3 in the image below:
I tried to copy the default script generated on the table, which looks like the image below, but I dont  think that's the right way to script it since values vary every time I have new data.
Thanks in advance!
Re: Script for exporting capability indices as data table
Here is a script that does what you want.  It uses the Semiconduct Capability data table as it's data source, but with simple changes, you should get what you want.
Names Default to Here( 1 );
dt= open("$SAMPLE_DATA/semiconductor capability.jmp");
ci=Capability(
      Y(:NPN1, :PNP1, :PNP2, :NPN2, :PNP3 ),
      Capability Indices Report( 1 )
report(ci)["Capability Indices"][1]<<make into data table;
ci=Capability(
switzal87
thanks a lot! that was a great help!
